Caso de estudo
FARO Laser Tracker used in NASA’s Ares I Project
FARO Laser Tracker used in NASAs Ares I Project
CASE STUDY:
NASA Langley Research Center is facilitating the build-up of the Ares I Crew Module, the Launch Abort System and the Separation Ring Assembly. With the high accuracy requirements when building these items, the Research Center has turned to laser tracker technology. The Research Center chose the FARO® Laser Tracker due to its affordable cost, portability and accuracy.
Eliminating the issue of not being able to take measurements directly in the manufacturing/production environment, from beginning to end the Laser Tracker facilitated the establishment of the most accurate Flight Test Article (FTA) possible.
Caso de estudo
Fabricação
Aeroespacial
Laser trackers
Conhecimento
Conteúdo relacionado
Brochure
CAM2: The Ultimate 3D Measurement Software Companion
FARO® CAM2® Software is designed to enable users to fulfill their quality assurance and inspection tasks with five software offerings, each one tailored to meet specific manufacturing measurement needs.
