웨비나/프레젠테이션 녹화
GD&T: revolutionizing your inspection workflows
다운로드 준비가 거의 완료되었습니다!
이 콘텐츠에 액세스하려면 사용자 정보를 좀 더 알려주세요.
How geometric dimensioning & tolerancing drive QA practices & how new tools make it painless, save time & avoid costly errors
Are your GD&T assurance processes as lean, accurate and efficient as they could be?
Watch this latest webinar as we dive into the benefits and challenges of implementing best practices in GD&T and other metrology processes. Starting with a crash course in the basics of interpreting tolerances, we then dig deeper and show you how to avoid common pitfalls of GD&T evaluation shortcuts – showing you how to save time and eliminate costly errors!
Are you challenged with implementing GD&T into your design and manufacturing processes?
GD&T must be evaluated the RIGHT WAY, to make sense for your specific industry and application. We will show you how the latest software and hardware work together to revolutionize the execution and implementation of GD&T strategies, while driving clarity and QA improvement throughout the entire development and manufacturing process.
This is a fact-filled and educational webinar you'll definitely want to watch!
Watch this webinar to:
  • Explore practical application of GD&T in manufacturing
  • Learn how to interpret common tolerances
  • See how software/hardware combinations for implementing and executing GD&T generate superior inspection workflows and reporting
  • Learn how to use a laser tracker in large assembly and roll alignment, from measurement to evaluation and even troubleshooting (featuring FARO ® BuildIT and VantageS6 with 6Probe)
  • See how to use measurement arm’s and laser line probes to assign and test tolerances (featuring QuantumS FaroArm ® with 8-Axis and PRIZM™ LLP)
Meet our expert presenter:
Renaud Gaboriault Bédard is an Automation Engineer who specializes in integrating FARO hardware and software with external systems to create fully automated solutions. As a part of the FARO BuildIT & 3D Solutions teams, he has worked to implement customized automated solutions for some of the largest industrial manufacturing clients around the world in the consumer electronics, automotive and aerospace industries.
Renaud holds a Bachelor of Mechanical Engineering degree from l'École Polytechnique de Montréal.
웨비나/프레젠테이션 녹화
제조
품질 관리
항공 우주
자동차
중장비
측정 서비스 제공자
금속세공, 가공 및 조립
고무 및 플라스틱
휴대용 측정 암
레이저 트래커
소프트웨어 - 계측 및 품질 관리
양자
PRIZM LLP
품질 관리 및 검사(BP)
지지
