웨비나/프레젠테이션 녹화
다운로드 준비가 거의 완료되었습니다!
이 콘텐츠에 액세스하려면 사용자 정보를 좀 더 알려주세요.
Join FARO's Will Pitarello, a Senior Applications Specialist in this unique learning opportunity to discover how the new Leap ST handheld 3D scanner and CAM2 Software will greatly enhance your precision measurement needs.
The 45-min recorded virtual event will explore how Leaps ST's excellent data rate and the ability to switch between modes will enable manufacturers to scan parts in less time with high accuracy, along with industry-leading software data processing and analysis.
Whether it's inspecting engine chassis, deep hole access, or ensuring quality assurance in aircraft wing construction, turbines and fuselages, Leap ST and CAM2 have your scanning and data analysis needs covered.
Learn how to:
  • Multiple operating modes in one device offers high versatility and increases your application fit
  • Optical configuration allows the placement of fewer targets
  • Blue laser, infrared, and photogrammetry technology and optical filters makes it possible to scan almost any surface
  • Confirm operator results:VDI/VDE 2634 certified devices can make the difference in the manufacturing business
Presenter:
Will Pitarello
Will Pitarello | Senior Application Specialist | FARO Technologies
Will has 10 years’ experience as a Senior Application Specialist for 3D Metrology at FARO and 15 years’ experience at the company. He has degrees in Industrial Engineering and Business Administration.
웨비나/프레젠테이션 녹화
품질 관리 및 검사(BP)
건설 품질 관리
생산, 제조, 조립
품질 관리
항공 우주
자동차
중장비
금속세공, 가공 및 조립
조선
Leap ST
3D 스캐너
FARO
제조
엔지니어링 및 설계
ARTÍCULO
¿Qué es el BIM y cómo repercute en la industria de la construcción?
Descubra cómo el modelado de información de la construcción (BIM) está revolucionando la industria de la construcción. Descubra qué es el BIM, cómo optimiza la colaboración, reduce los costos y mejora los resultados del proyecto, desde el diseño hasta la gestión de instalaciones.
