Mission Support Inc. overhauls U.S. Air Force B-52s using the FaroArm
Mission Support Inc overhauls US Air Force B-52s using the FaroArm
Mission Support Incorporated (MSI) is a service provider for major commercial aerospace companies, including performing the inspection of U.S. Air Force legacy aircraft components. MSI essentially remanufactures the bypass ducts of the B-52, often performing a complete disassembly/reassembly during overhaul.
Mission Support found it increasingly difficult to produce conforming products using the original hard tooling. To solve these issues, Mission Support uses a FARO® FaroArm® for both their production and QA inspection needs.
제조
품질 관리
제품 설계 및 엔지니어링
항공 우주
측정 서비스 제공자
휴대용 측정 암
양자
품질 관리 및 검사(BP)
인식
Brochure
BROCHURE
Vidéo
