기사
법의학을 위한 레이저 스캐닝을 사용하는 10가지 이유
forensic-ls
Laser scanning is rapidly gaining acceptance and becoming more and more commonplace in the law enforcement and accident reconstruction communities. Over the past few years, hardware and software have improved significantly creating a simpler, overall system to capture immense detail in a short period of time.
These are 10, of the many, reasons to consider laser scanners for a forensic application:
1) Easy to use: Many manufacturers are moving toward a simpler interface making operation of the scanner more like a digital camera than a complicated survey instrument.
2) Portability: Laser scanners are smaller in size today than ever before making them easier to deploy to a crime/accident scene and useable by just about anyone.
3) Safety: Data can be collected from a distance, with some scanners collected measurements over 300 meters away. This allows the operator to scan a scene out of harms way. In addition, laser scanners can collect up to 1,000,000 points per second with average scan times of several minutes. Less time on a scene means less time for potential danger to the individuals at the scene. Class I lasers are also being used in laser scanners creating a truly eye-safe environment during the scan.
4) Speed and Efficiency: Complete color scans can be captured in as little as several minutes creating a virtual scene with high accuracy and detail that can be revisited over and over without physically traveling to the site. In contrast to traditional methods of surveying/documenting a scene, laser scanning can be much faster and allow multiple investigators to have eyes on the virtual scene.
5) Produce a variety of deliverables: Once the scene has been laser scanned, various types of final products can be extracted or produced from the data. For example, anything from a traditional 2D drawing to a detailed 3D animation can be created from the scan data.
6) 동료의 압박 : 현장 문서화를 위해 레이저 스캐너를 사용하는 기관이 점점 더 많아지면서 그 결과는 더 널리 받아 들여지고 있습니다. 미래의 장면이 3D로 문서화 될 것이라는 기대치의 증가.
7) 비용 효과: 일반적으로 교통 사고를 문서화하는 데 사용되는 전체 스테이션과 가격 면에서 레이저 스캐너가 점점 비슷해지고 있습니다.
8) 특수 측정 도구 : 3D 데이터에서 법의학 분석을위한 소프트웨어에는 이제 혈액 튄 자국 및 총알 궤적, 목격자 / 용의자 높이 등을 측정하기위한 특수 도구도 포함됩니다.
9) 간편한 공유 : 소프트웨어를 설치하거나 추가 라이센스를 구매할 필요없이 스캔 데이터를보고 문서화하는 데 더 많은 소프트웨어 도구를 사용할 수 있습니다.
10) 장면 보관 : 장면이 레이저로 스캔되면 본질적으로 시간이 고정되어 장면을 조사하려는 사람의 향후 가상 방문을 위해 보존됩니다. 이를 통해 캡처 당시에도 중요하다고 생각되지 않을 수도있는 측정을 수행 할 수 있습니다.
기사
공용 안전 분석
범죄 현장 조사
사고 충돌 재구성
방화 조사
결함 조사
포렌식 엔지니어링
법 집행
3D 스캐너
초점
재구성 및 분석
비디오
Focus Premium Max 및 FARO® SCENE 결합을 통한 스캔
측량사 및 전문 프로젝트를 위한 선도적인 3D 레이저 스캐닝 정합 소프트웨어인 FARO® SCENE에 대해 알아보세요. 대화형 스캔 정합, 하이브리드 정합 및 고급 도구를 갖춘 SCENE은 원활한 geo-rerefencing 적용, 강력한 오류 수정 및 내보내기 유연성을 통해 3D 워크플로를 재정의합니다.
기술 사양서
Orbis Premium 모바일 스캐너의 정확성과 다양한 활용도 경험하기
FARO Orbis™ Premium 모바일 레이저 스캐너는 IP54 내구성, SLAM 스캔 기술, 72MP 이미지, 고밀도 Flash Technology 스캔을 갖춘 강력한 모바일 스캐너입니다.
WEBINAR RECORDING- ROA
Meet the New Focus Premium Max Laser Scanning Solution
Watch this webinar to learn how 3D technologies assist with geospatial, construction, and engineering workflows for enhanced efficiency and better project outcomes.
