ウェビナー/プレゼンテーション録画
Implementing 3D Laser Scanning for MEP Applications
ダウンロードの準備が整いました!
このコンテンツにアクセスしていただくために、もう少し詳しく教えていただけますか。
購読者は、各メール通知の下部に記載されている登録解除リンクをクリックすることで、いつでも同意を取り消すことができます。私たちはあなたのプライバシーを真剣に受け止めます。FAROがお客様の個人情報をどのように処理するかについての詳細は、 当社のプライバシーポリシーをご覧ください。
Watch this recording of Matthew Davies and Graham Tinker from a recent webinar designed to enlighten attendees as to the benefits of 3D laser scanning as it applies to MEP building systems.
The event detailed how to use the FARO® Focus Laser Scanner in order to obtain the best results as well as its related software so that as-built construction can inform the 3D model.
By the end of the recording, you will be able to understand how the FARO Focus Laser Scanner can help capture physical components. Attendees will also be more proficient using As-BuiltTM Software to compare 3D models to in-field MEP installations as well as to create MEP system drawings.
Presenter:
Kyle Tarr
Matthew Davies
Matthew Davies studied Mechanical Engineering at University and spent 9 years working in industrial metrology. He joined FARO in 2019, his experience in manufacturing is helping AEC customers with faster, more accurate surveys.
Kyle Tarr
Graham Tinker
Graham Tinker joined FARO In October 2021, with a background of using Revit and AutoCad. Graham is an Application Engineer for the AEC team at FARO, for the northern region, and has extensive knowledge across all the FARO products including Focus Scanners, SCENE, BuildIt, and As-Built.
Derek Lawrance
Derek Lawrence, Owner, Twindl Ltd
Derek is a Chartered Design Engineer with over 20 years of experience working in the world’s leading engineering and property consultancies. Derek has a deep understanding of evolving digital visualisation tools and is actively involved supporting artists virtually protype and communicate their ideas though virtual, augmented and mixed reality.
ウェビナー/プレゼンテーション録画
As-Builtキャプチャとモデリング
検討
建築と建設
建築、エンジニアリング、建設
As-Built
3Dスキャナー
ソフトウェア - 建築、エンジニアリング、建設
建築、エンジニアリング、建設
ニュースレターを購読して最新情報を入手してください。
関連コンテンツ
フィルタ
フィルタ
