ウェビナー/プレゼンテーション録画
From precise scan to workable 3D model
ダウンロードの準備が整いました!
このコンテンツにアクセスしていただくために、もう少し詳しく教えていただけますか。
購読者は、各メール通知の下部に記載されている登録解除リンクをクリックすることで、いつでも同意を取り消すことができます。私たちはあなたのプライバシーを真剣に受け止めます。FAROがお客様の個人情報をどのように処理するかについての詳細は、 当社のプライバシーポリシーをご覧ください。
[送信] をクリックすると、FARO またはその公式パートナー/販売代理店からの回答を受け取ることに同意したとみなされます。
Want to learn how you can eliminate unwanted surprises in your construction process?
FARO® As-Built™ Software ensures that architects and engineers efficiently create building designs based on precise data that’s fully compatible with CAD and BIM systems.
As-Built maximizes productivity, saving time and effort by preventing multiple visits to construction sites. Having accurate as-built data from the site accessible on your computer means it can be used on future project updates, amortizing the cost of the initial investment.
Knowing how to properly utilize this software will reduce the time for information extraction from point cloud data and get the job done right, so you and your customers can tackle the next big project.
But what use is that data if you don’t know how to work with it? In this webinar, you’ll learn how to get the most from the As-Built software solutions.
Presenters:
Mohit
Mohit Baunthiyal
Application Engineer, FARO
Mohit Baunthiyal is an Application Engineer for FARO Technologies, India and provides technical expertise on FARO 3D Laser Scanning hardware and software solutions for the AEC (i.e., Architecture, Engineering & Construction) industry. Mohit has more than 7 years experience in the field for Mine Planning, Aerial Surveying, 3D Laser Scanning, GIS & allied businesses.
Nagaraja
Mr V. Nagaraja
Director, MAPPA
Mr V. Nagaraja is currently working as the director in MAPPA with more than 20 years of survey experience. Mappa is Faro Distributor and Service Provider Of 3D Terrestrial Laser Scanning and Lidar Services. They have good capability of acquiring and processing LiDAR data for infrastructure projects, plant engineering, Mining and As-Built Modeling. They have recently completed 3D scanning of more than 10 plants all over the globe, the total area exceeding 5 lakh sq mts.
建築、エンジニアリング、建設
ウェビナー/プレゼンテーション録画
モバイルマッピングシステム
As-Built
As-Builtキャプチャとモデリング
ソフトウェア - 建築、エンジニアリング、建設
ニュースレターを購読して最新情報を入手してください。
関連コンテンツ
フィルタ
フィルタ
