記事
Forensic experts reduce overtime by 25% & improve courtroom deliverables
33 SocialMedia TechValidate case PS AM EN-768x403
SUCCESS CASE: OEC Forensics Achieves Complete Preservation of Evidence with 3D Laser Scanning
Forensic experts reduce overtime 25% & improve courtroom deliverables
As a forensic engineering firm specialized in motor vehicle collision analysis and reconstruction, OEC Forensics is dependent on their expert team and the latest technology to analyze physical evidence, ensure objective results and maintain a commitment to accuracy and reliability.
However, OEC Forensics found themselves with a few challenges in achieving these objectives, and set out to assess and find a solution.
THE CHALLENGE:
OEC Forensics had a few challenges that were limiting their efficiency and quality of client deliverables:
  • They were spending too much time on the scene collecting data
  • They sometimes found they had missed measurements
  • They did not have a method for documenting scenes in a way that provides compelling courtroom presentations
  • And they had a problem obtaining higher levels of precision and accuracy when they had to occupy the point of interest
THE USE CASE:
To best assess what solutions they should consider, they had to evaluate the particulars of their current operations:
COMPANY OVERVIEW:
  • Size: 5-9 employees
  • Industry: Forensic Services
TYPICAL APPLICATIONS:
OEC Forensics’ engineers gather evidence, analyze the obtained data and develop conclusions regarding, but not limited to, the following areas:
  • Severity
  • Causation
  • Rules of the road
  • Driver avoidance issues
  • Comparative negligence
  • Occupant kinematics
  • Safety system use and operation
  • Contribution to the collision from vehicle components and roadway elements
PREVIOUS SOLUTION:
Scene documentation methods included:
  • Tape measure
  • Total station
  • Camera / photogrammetry
The root cause of their problem became evident – their current scene documentation and measurement methods were not efficient or effective.
That is when they turned to 3D laser scanning technology for a superior data collection solution that allowed for complete digitalization of incident scenes – the FARO Focus Laser Scanner and the FARO Freestyle3D Handheld Scanner.
THE RESULTS:
Upon adopting the FARO Focus Laser Scanner and FARO Freestyle3D Handheld Scanner, OEC Forensics achieved significant success and improvement to their processes:
  • They achieved dramatically more accurate measurements
  • They were able to generate 3D representation of scenes
  • They improved safety and precision by being able to stand away from the subject, such as a busy road
  • They decreased overtime by about 25% since using the Focus and Freestyle3D
  • And they saw the quality of presentations and courtroom deliverables greatly improved
“[FARO] allows for the complete documentation of a subject, whether it be a roadway, vehicle, oil field or some other type of complex geometry. The high-definition point cloud data allows for accurate and precise measurement of points of interest, as well as thorough documentation of data that is often overlooked or inadvertently missed while documenting using traditional methods.”
-Jerry Ogden, PhD, OEC Forensics
HOW YOU CAN ACHIEVE THESE RESULTS:
FARO’s solutions can help you digitally capture a crime, crash or fire scene, analyze the data in 3D and deliver significantly more impactful courtroom material.
From our hardware – such as the FARO Focus Laser Scanners and FARO Freestyle3D Handheld Laser Scanner – to our application software – such as FARO SCENE and FARO Zone 3D and 2D – we engineer our solutions specifically for public safety and forensics professionals.
*This success case of OEC Forensics is based on an April 2017 survey of FARO Technologies, Inc. customers conducted by TechValidate, a 3rd-party research service.
記事
公共の安全分析
クラッシュ再現
クラッシュ再現
法廷でのプレゼンテーション
警察
3Dスキャナー
Freestyle
検察と管理
認知
ニュースレターを購読して最新情報を入手してください。
関連コンテンツ
フィルタ
フィルタ
solution de sécurité publique : Améliorer la sécurité grâce à la capture de la réalité
Transformez le travail de votre équipe en matière de sécurité publique grâce à la capture de la réalité en 3D. effet de levier 3D réalité capture et avancé logiciel forensic analysis, Plan de préparation à l'incident, and smarter, safer sécurité publique process.
Vidéo
INFOGRAPHIE
Un appareil de capture de réalité 3D FARO pour répondre à vos besoins en matière de vitesse et de précision
Comment le FARO® Orbis Mobile Scanner, qui fournit des numérisations mobiles ainsi que des numérisations Flash de qualité, s'intègre dans un flux de travail avec la solution Hybrid Reality Capture, développée par Flash Technology, et le FARO® Focus Premium Laser Scanner.
