Registrazione webinar/presentazione
Meet the New Focus Premium Max Laser Scanning Solution
Il tuo download è quasi pronto!
Fornisci qualche informazione in più su di te per accedere a questo contenuto.
Facendo clic su Invia, accetti di ricevere una risposta alla tua richiesta da parte di FARO o da uno dei suoi partner/distributori ufficiali.
Whether you’re scanning real-world data for construction, geospatial, engineering, or public safety, the Focus scanner paired with the FARO Stream App, FARO SCENE Software, and the FARO Sphere® XG Digital Reality Platform ensures enhanced workflow efficiency.
If you’re concerned about how much time you’re spending in the field and you want to see if you can save time and money, the Focus Premium Max might be just what you need to improve your workflow efficiency.
Watch this video to learn how the Focus solution can:
  • Increase speed and efficiency with Flash Technology scans.
  • Provide you with real-time scanning insights via the FARO Stream App — no more “scanning blind” when you’re on the job site!
  • Connect with FARO Sphere XG for fast, efficient data management.
  • Enhanced your data processing time in FARO SCENE Software.
  • Provide you with the option to store data in the cloud or offline.
Presenters:
Mohit Baunthiyal
Mohit Baunthiyal | Account Manager | FARO Technologies
Mohit Baunthiyal works for FARO Technologies as an Account Manager, specializing in 3D reality capture solutions for the Architecture, Engineering, Construction & Operations segment.
Ajeet Kanaujia
Ajeet Kanaujia | Field Applications Engineer | FARO Technologies
Ajeet Kanaujia is a Field Applications Engineer with expertise in 3D scanning for digital twins, the architecture, engineering, construction and operations segment, and the public safety segment.
Watch now learn how 3D reality capture solutions can save you time and money on your next project!
Sostegno
Consapevolezza
Costruzione e edilizia
Raccolta
Design e pianificazione
Manutenzione ed esercizio
Ricostruzione e analisi
Rilevamento e misurazione
Indagini su incendi dolosi
Controllo della qualità edile
Ricostruzione di incidenti
Tecnologia Digital Twin per la gestione di risorse e strutture
Indagini sui guasti
Preservazione storica
Pianificazione della sicurezza
Energia e risorse naturali
Incendi e soccorso
Ingegneria forense
Silvicoltura
Geospaziale
Assicurazioni
Forze dell'ordine
Scanner 3D
App e plugin
Video
ARTICOLO
sicurezza pubblica soluzione: Migliorare la sicurezza con realtà Capture
Trasforma il lavoro di sicurezza pubblica del tuo team con l'acquisizione della realtà 3D. Sfrutta l'acquisizione 3D della realtà e il n/a software per l'analisi forense, la pianificazione pre-incidente e processi di sicurezza pubblica più intelligenti e sicuri.
