Registrazione webinar/presentazione
Meet the New Focus Premium Max Laser Scanning Solution
Il tuo download è quasi pronto!
Fornisci qualche informazione in più su di te per accedere a questo contenuto.
Facendo clic su Invia, accetti di ricevere una risposta alla tua richiesta da parte di FARO o da uno dei suoi partner/distributori ufficiali.
Whether you’re scanning real-world data for construction, geospatial, engineering, or public safety, the Focus scanner paired with the FARO Stream App, FARO SCENE Software, and the FARO Sphere® XG Digital Reality Platform ensures enhanced workflow efficiency.
If you’re concerned about how much time you’re spending in the field and you want to see if you can save time and money, the Focus Premium Max might be just what you need to improve your workflow efficiency.
Watch this video to learn how the Focus solution can:
  • Increase speed and efficiency with Flash Technology scans.
  • Provide you with real-time scanning insights via the FARO Stream App — no more “scanning blind” when you’re on the job site!
  • Connect with FARO Sphere XG for fast, efficient data management.
  • Enhanced your data processing time in FARO SCENE Software.
  • Provide you with the option to store data in the cloud or offline.
Presenters:
Mark Lane
Mark Lane | Account Manager | FARO Technologies
Mark has a background in terrestrial laser scanning, mobile mapping and BIM. His areas of expertise include scan to BIM, mine progress mapping, flatness analysis, and structural monitoring.
Peter Mandak
Peter Mandak | Sr. Field Applications Engineer | FARO Technologies
Peter supports the architecture, engineering, construction, and public safety sectors. He holds a degree in Mechanical Engineering from the Higher Training & Research Institute of Engineering in Vienna.
Watch now to learn how 3D reality capture solutions can save you time and money on your next project!
Sostegno
Consapevolezza
Costruzione e edilizia
Raccolta
Design e pianificazione
Manutenzione ed esercizio
Ricostruzione e analisi
Rilevamento e misurazione
Indagini su incendi dolosi
Controllo della qualità edile
Ricostruzione di incidenti
Tecnologia Digital Twin per la gestione di risorse e strutture
Indagini sui guasti
Preservazione storica
Pianificazione della sicurezza
Energia e risorse naturali
Incendi e soccorso
Ingegneria forense
Silvicoltura
Geospaziale
Assicurazioni
Forze dell'ordine
Scanner 3D
App e plugin
Video
Qu'est-ce que la BIM et quel est son impact sur le secteur de la construction ?
Découvrez comment la modélisation des informations du bâtiment (BIM) révolutionne le secteur de la construction. Découvrez ce qu'est la BIM, comment elle rationalise la collaboration, réduit les coûts et améliore les résultats des projets, de la conception à la gestion des bâtiments.
