Reinventing the Wagener Building
The Wagener Building, a three-story, 140-year-old brick and timber-framed structure, commands a storied place in Charleston’s history. The new owner's ultimate goal is to turn the Wagener into the region’s premier events center, capable of staging everything from lavish weekend weddings to technically sophisticated corporate presentations, all while honoring the building’s amazing history. The team appointed for the renovation used a FARO® Laser Scanner to capture a point cloud, SCENE software for data registration, and As-Built™ software to create a model that was used to complement survey measurements, as another layer of as-built verification.
Conservation du patrimoine
Scanners 3D
As-Built
Inspection et mesures
Prise de conscience
Filtres
Filtres
ARTICOLO
sicurezza pubblica soluzione: Migliorare la sicurezza con realtà Capture
Trasforma il lavoro di sicurezza pubblica del tuo team con l'acquisizione della realtà 3D. Sfrutta l'acquisizione 3D della realtà e il n/a software per l'analisi forense, la pianificazione pre-incidente e processi di sicurezza pubblica più intelligenti e sicuri.
