Grabación de webinar/presentación
GD&T: revolutionizing your inspection workflows
Su descarga está casi lista.
Cuéntenos un poco más sobre usted para acceder a este contenido.
Al hacer clic en enviar, acepta recibir una respuesta a su solicitud de parte de FARO o de uno de sus socios/distribuidores oficiales.
How geometric dimensioning & tolerancing drive QA practices & how new tools make it painless, save time & avoid costly errors
Are your GD&T assurance processes as lean, accurate and efficient as they could be?
Watch this latest webinar as we dive into the benefits and challenges of implementing best practices in GD&T and other metrology processes. Starting with a crash course in the basics of interpreting tolerances, we then dig deeper and show you how to avoid common pitfalls of GD&T evaluation shortcuts – showing you how to save time and eliminate costly errors!
Are you challenged with implementing GD&T into your design and manufacturing processes?
GD&T must be evaluated the RIGHT WAY, to make sense for your specific industry and application. We will show you how the latest software and hardware work together to revolutionize the execution and implementation of GD&T strategies, while driving clarity and QA improvement throughout the entire development and manufacturing process.
This is a fact-filled and educational webinar you'll definitely want to watch!
Watch this webinar to:
  • Explore practical application of GD&T in manufacturing
  • Learn how to interpret common tolerances
  • See how software/hardware combinations for implementing and executing GD&T generate superior inspection workflows and reporting
  • Learn how to use a laser tracker in large assembly and roll alignment, from measurement to evaluation and even troubleshooting (featuring FARO ® BuildIT and VantageS6 with 6Probe)
  • See how to use measurement arm’s and laser line probes to assign and test tolerances (featuring QuantumS FaroArm ® with 8-Axis and PRIZM™ LLP)
Meet our expert presenter:
Renaud Gaboriault Bédard is an Automation Engineer who specializes in integrating FARO hardware and software with external systems to create fully automated solutions. As a part of the FARO BuildIT & 3D Solutions teams, he has worked to implement customized automated solutions for some of the largest industrial manufacturing clients around the world in the consumer electronics, automotive and aerospace industries.
Renaud holds a Bachelor of Mechanical Engineering degree from l'École Polytechnique de Montréal.
Manufactura
Aeroespacial
Automotriz
Equipos pesados
Caucho y plástico
Brazos de medición portátiles
Laser Trackers
PRIZM LLP
Recomendación
Contenido relacionado
Escaneo 3D líder en la industria, fundamental para mediciones rápidas
Aprenda cómo la excelente velocidad de datos de Leap ST y sus cinco modos permiten a los fabricantes escanear piezas en menos tiempo y con alta exactitud.
ARTÍCULO
¿Qué es el BIM y cómo repercute en la industria de la construcción?
Descubra cómo el modelado de información de la construcción (BIM) está revolucionando la industria de la construcción. Descubra qué es el BIM, cómo optimiza la colaboración, reduce los costos y mejora los resultados del proyecto, desde el diseño hasta la gestión de instalaciones.
