Watch this recording of Matthew Davies and Graham Tinker from a recent webinar designed to enlighten attendees as to the benefits of 3D laser scanning as it applies to MEP building systems.
The event detailed how to use the FARO® Focus Laser Scanner in order to obtain the best results as well as its related software so that as-built construction can inform the 3D model.
By the end of the recording, you will be able to understand how the FARO Focus Laser Scanner can help capture physical components. Attendees will also be more proficient using As-BuiltTM Software to compare 3D models to in-field MEP installations as well as to create MEP system drawings.
Presenter:
Matthew Davies Matthew Davies studied Mechanical Engineering at University and spent 9 years working in industrial metrology. He joined FARO in 2019, his experience in manufacturing is helping AEC customers with faster, more accurate surveys. |
Graham Tinker Graham Tinker joined FARO In October 2021, with a background of using Revit and AutoCad. Graham is an Application Engineer for the AEC team at FARO, for the northern region, and has extensive knowledge across all the FARO products including Focus Scanners, SCENE, BuildIt, and As-Built. |
Derek Lawrence, Owner, Twindl Ltd Derek is a Chartered Design Engineer with over 20 years of experience working in the world’s leading engineering and property consultancies. Derek has a deep understanding of evolving digital visualisation tools and is actively involved supporting artists virtually protype and communicate their ideas though virtual, augmented and mixed reality. |
