Webinar/Presentation Recording
Combining laser scans with drone footage for investigations
Your download is almost ready!
Tell us a little more about you to access this content.
Using LiDAR & UAV data for faster, more complete scene capture
No two scenes are the same and each brings its unique set of challenges.
They can happen day or night, in any weather and with any number of other circumstances. You need a bird's eye view for context but also a high-level accuracy for evidence capture. It needs to be complete, accurate and, at times, done quickly to open roads faster, reduce time on scene or to go to the next call.
Sounds like a tall order, right?
By using both laser scanners and drones, you can capture the scene efficiently and merge the data to create a complete view of the scene memorialized in 3D where you can revisit and analyze anytime.
Watch this webinar to:
  • Understand how drones and laser scanners work together to document a scene
  • Dive into scenarios and applications when it is the best to use
  • Learn step-by-step the process to merge drone data with laser scanner data in FARO Zone
  • Hear from industry experts and users leverage this technique
Meet the presenters and panelists:
  • Russ Boynton - Forensic Specialist, FARO
  • Eric Dustin - Forensic Specialist, FARO
  • Dean Pierson - Application Engineer, FARO
  • David Dustin - Director of Product Management, FARO
  • Mark Johnson - CEO, Visual Law
  • Jason Price - Midwest Aero Technologies
Public Safety Analytics
Crime Scene Investigation
Law Enforcement
FARO Zone
Collection
solution de sécurité publique : Améliorer la sécurité grâce à la capture de la réalité
Transformez le travail de votre équipe en matière de sécurité publique grâce à la capture de la réalité en 3D. effet de levier 3D réalité capture et avancé logiciel forensic analysis, Plan de préparation à l'incident, and smarter, safer sécurité publique process.
Vidéo
INFOGRAPHIE
Un appareil de capture de réalité 3D FARO pour répondre à vos besoins en matière de vitesse et de précision
Comment le FARO® Orbis Mobile Scanner, qui fournit des numérisations mobiles ainsi que des numérisations Flash de qualité, s'intègre dans un flux de travail avec la solution Hybrid Reality Capture, développée par Flash Technology, et le FARO® Focus Premium Laser Scanner.
