Webinar/Presentation Recording
Deploying 3D Reality Capture for Bridge Inspection Applications: Field to Finish
Your download is almost ready!
Tell us a little more about you to access this content.
Watch this video presentation and join us as we dive into the world of 3D reality capture technology for bridge inspection applications — covering everything from data acquisition to final analysis and reporting. This video presentation explores the comprehensive process of utilizing cutting-edge technology to enhance efficiency and accuracy in bridge inspection projects.
Key Points Covered:
  • Reality Capture Technology: Understand the essential requirements for deliverables in bridge inspection projects and how reality capture technology meets these demands.
  • Data Registration: Discover best practices for interactive registration to integrate multiple LiDAR scans into a single point cloud representation — and learn how to leverage registration reports to ensure precise alignment and accuracy.
  • As-Built 3D Modeling: Learn how to generate accurate as-built 3D models of bridges using point cloud data.
  • Beam Camber: Explore the process of analyzing beam camber using reality capture data and discover techniques for fitting beams intelligently within point cloud data.
  • Time-Based Deviation Analysis: Understand how to perform time-based deviation analysis by comparing point clouds to structural elements over time.
Don’t miss the opportunity to stay ahead in the field of bridge inspection with the latest advancements in reality capture technology — watch the video now.
Presenters:
Kelly Obermeyer
Kelly Obermeyer | Field Applications Engineer | FARO Technologies
Kelly Obermeyer is a Field Applications Engineer and as-built product expert at FARO Technologies. She graduated with a civil engineering degree and began her career in the oil and gas industry. Kelly’s first role involved using a handheld scanner to measure corrosion on pipelines to obtain measurements for burst pressure calculations. After finding success using a handheld scanner, her team expanded to working with long-range 3D scanners. She used a FARO Focus Laser Scanner to scan pump stations, refineries, and offshore rigs, then registered the data in FARO SCENE Software, and used FARO’s As-Built plugin for AutoCAD®️ Plant3D to create 3D models and isometric drawings. After seven years of field work, Kelly joined FARO, where she has worked for the past three years.
Russell Boynton
Noah Wells | Field Applications Engineer | FARO Technologies
Noah Wells is a Field Applications Engineer for FARO Technologies, Inc. He joined FARO in 2021 as part of the New Graduate Development Program and serves the Northwest and California regions.
Advocate
Build & Construct
Design & Plan
Maintain & Operate
Surveying & Measurement
As-Built Capture & Modeling
Construction Quality Control
Energy & Natural Resources
Insurance
As-Built
비디오
Focus Premium Max 및 FARO® SCENE 결합을 통한 스캔
측량사 및 전문 프로젝트를 위한 선도적인 3D 레이저 스캐닝 정합 소프트웨어인 FARO® SCENE에 대해 알아보세요. 대화형 스캔 정합, 하이브리드 정합 및 고급 도구를 갖춘 SCENE은 원활한 geo-rerefencing 적용, 강력한 오류 수정 및 내보내기 유연성을 통해 3D 워크플로를 재정의합니다.
기술 사양서
Orbis Premium 모바일 스캐너의 정확성과 다양한 활용도 경험하기
FARO Orbis™ Premium 모바일 레이저 스캐너는 IP54 내구성, SLAM 스캔 기술, 72MP 이미지, 고밀도 Flash Technology 스캔을 갖춘 강력한 모바일 스캐너입니다.
WEBINAR RECORDING- ROA
Meet the New Focus Premium Max Laser Scanning Solution
Watch this webinar to learn how 3D technologies assist with geospatial, construction, and engineering workflows for enhanced efficiency and better project outcomes.
