Tech Sheet
VantageS6 Max and VantageE6 Max Laser Trackers
Vantage S6 & E6 Laser Trackers
Large-Scale, High-Accuracy, Portable Dynamic 6DoF Probing
FARO® VantageS6 Max and VantageE6 Max Laser Trackers enable you to build and inspect products by measuring quickly, simply and precisely with exceptional portability. The Vantage Max Laser Trackers offer comprehensive, large-volume 3D measurement up to 80 meters, significantly streamlining your processes and reducing inspection cycle times while ensuring complete confidence in the results.
New to the Vantage Max is more accurate 6 degrees of freedom (6DoF) measurement capabilities via the optional 6Probe, which enables precise measurement of hidden areas and small features. 6DoF probing helps speed up your inspections and reduce the number of device moves, resulting in a productivity improvement of 20% compared to lower accuracy probes.
Download the Tech Sheet to learn more about how the Vantage Max can help your organization throughput while maintaining high inspection accuracy.
Tech Sheet
Quality Control & Inspection
Shipbuilding
Measurement Service Providers
Heavy Equipment
Aerospace
Automotive
Laser Trackers
Consideration
Engineering & Design
Production & Assembly
6Probe
Video
Tech Sheet
Gage Max FaroArm
Download the FARO® Gage Max FaroArm tech sheet to explore precise measurement capabilities, key features, specifications, and industry applications.
