Tech Sheet
Tracer M Laser Projector
3D Laser Projector for Laser-Guided Assembly and Production
The FARO® TracerM Laser Projector accurately projects a laser line onto a surface or object, providing a virtual template which operators and assemblers use to quickly and accurately position components with absolute confidence. The laser template is created using a 3D CAD model which enables the system to visually project a laser outline of parts, artifacts or areas of interest. The result is a virtual and collaborative 3D template to streamline a wide range of assembly and production applications.
Laser projection technology uses CAD files to provide a virtual templating solution which eliminates the need for physical templates and hard tooling, and reduces the risk of human error. As a result, organizations are able to avoid the time and expense associated with using large, heavy templates while significantly improving quality control processes. An easy-to-use operator interface minimizes both the time and the skill required for operation.
The TracerM Laser Projector is the ideal solution for any organization seeking to improve quality and efficiency. The ability to guide a process sequence, along with accurately locating and orienting components, increases manufacturing efficiencies. Costly non-conformances are eliminated by implementing a simple, reliable and cost-effective solution to streamline production processes.
Tech Sheet
Design Layout & Projection
Aerospace
Automotive
Shipbuilding
Heavy Equipment
Laser Projectors
Tracer
Production & Assembly
Consideration
