Tech Sheet
BuildIT Construction Software
Construction Software Platform for AEC Professionals
Construction sites are becoming remote factories in need of build and verify solutions. Historically, the tolerance level for scrap and rework has been very high because it’s considered part of the normal business - until now. FARO® introduces BuildIT Construction, the first fully integrated building lifecycle Quality Assurance (QA) and Quality Control (QC) management tool empowering construction professionals to continuously evaluate projects with real-time comparisons against CAD designs using 3D scan data.
BuildIT Construction uniquely enables laser scanner users to perform immediate, -real-time build and verify analysis throughout the entire project and facilitates a new level of cost management and operational efficiency.
This software is applicable to various industry applications, including architecture, civil/survey, construction, facility management, historical preservation, mechanical, electrical and plumbing (MEP) and more.
Tech Sheet
Construction Quality Control
Build & Construct
Consideration
ARTICOLO
sicurezza pubblica soluzione: Migliorare la sicurezza con realtà Capture
Trasforma il lavoro di sicurezza pubblica del tuo team con l'acquisizione della realtà 3D. Sfrutta l'acquisizione 3D della realtà e il n/a software per l'analisi forense, la pianificazione pre-incidente e processi di sicurezza pubblica più intelligenti e sicuri.
