“Superpower” Boost: The Dynamic Duo of Laser Trackers and the 6DoF Probe
FARO's Dynamic Duo of Laser Trackers and the 6DoF Probe
For industries that regularly perform large-scale measurements, laser trackers are metrology’s “super tool” of choice offering accurate 3D measurements collected by a single operator. They are ideal for alignment, machine installation, maintenance, part and assembly inspection, tool/die/mold building, reverse engineering, and robot calibration.
Contrary to dated perceptions, modern laser trackers are easy to use. Nor is absolute line-of-site a must. Historically, measuring was a highly manual effort requiring absolute line-of-sight between the tracker and the SMR. If anything got between the two, the laser line would be broken, and the user would have to manually find the laser again. In order to use these early trackers efficiently, operators needed extensive training and lots of experience.
Read on to learn how different companies have dramatically reduced measurement time, even with large or complicated objects.
Product Design & Engineering
Quality Control & Inspection
Production & Assembly
Aerospace
Automotive
Heavy Equipment
Shipbuilding
Laser Trackers
6Probe
導入事例
Orbisで売上を倍増:林測量技術コンサルタント株式会社の導入事例
林測量技術コンサルタント株式会社が、FARO® Orbis Mobile Scannerを活用して従業員の効率をどのように変革し、売上倍増を実現したかをご覧ください。
記事
BIMとは何で、建設業界にどのような影響を与えますか?
BIM(ビルディングインフォメーションモデリング)が建設業界にどのように革命をもたらしているかをご紹介します。BIMとは何で、協業をどのように合理化し、コストを削減し、設計から施設管理までのプロジェクト成果を向上させるのかをご説明します。
