Speed, Accuracy, Sustainability:
The Benefits of 3D Laser Scanning for Mass Timber Construction
Originally Published in PBC Today
Speed, Accuracy, Sustainability: The Benefits of 3D Laser Scanning for Mass Timber Construction
The calendar may have read January, but for millions of Europeans it felt more like May or even June as "winter" temperatures soared. When heat waves happen, it’s natural for thoughts to turn to human-accelerated climate change and the ways in which sustainability measures must be implemented in order to reduce the release of planet-warming gases.
Considering that the built environment contributes up to 40% of global CO2 emissions (14.6 gigatons), increasing the odds of more out-of-season scorchers, it’s imperative that the construction industry in the U.K. and around the world work to address the problem.
Fortunately, there are two solutions rapidly gaining traction that contractors, structural engineers and architects would be wise to adopt: mass timber construction for the actual build, and 3D laser scanning that enables accurate and reliable as-built data capture and documentation: essential for progress monitoring, efficiency gains, faster project completion and construction verification.
Mass Timber for the Masses
Unlike traditional log homes or even homes made from wood, mass timber is a composite material. Typically made from pine, spruce, or fir, when layered together with adhesives to form panels and beams, it can rival steel in terms of its strength and durability.
According to a 2022 report by The Council on Tall Buildings and Urban Habitat (TCBU), there were 139 mass timber buildings in the world eight stories or higher and 71% of them are in Europe with more on the way.
In the U.K., wooden skyscrapers have gotten a lot of media attention of late and the City of London is considering a legislative rules change to allow taller wood structures in the future, like the planned Oakwood Tower, slated to be built in the heart of London’s Barbican Estate, a Grade II listed concrete residential complex.
Overall, mass timber buildings are lightweight relative to their load-bearing capability, are made from a sustainable source (wood harvested from protected forests to ensure a balanced cycle of cutting and replacing), have excellent thermal properties (lowering a building’s HVAC costs and energy usage) and feature a reduced carbon footprint due to the chemical element already being sequestered in the wood itself, not to mention the reduced equipment/personnel required on-site since mass timber is a prefabricated product manufactured in controlled environments.
Today Mass Timber Article
3D Point Cloud Power
As noted in this article’s title, speed and accuracy are the chief advantages of incorporating 3D laser scanning into mass timber construction.
This is true for any as-built building material like steel or reinforced concrete, but even more so when dealing with wood. For instance, while wood has long been prized for its aesthetics and considered a finishing material, structural timber introduces temperature stability issues, causing elongation or shortening and member connection accuracy for fit-up and detailing.
Beyond wood-specific needs, new construction projects involve many different stakeholders that depend on project information in the form of drawings, submittals, imagery and models, etc.
Subcontractors, too, are integral to the construction process as each one is focused on a separate but interrelated task. In these complex projects, progress depends on each subtask and each subsystem (MEP, for instance) working seamlessly. 3D laser scanning ensures a complete and accurate record of a build’s as-built condition. And it allows multiple subcontractors and stakeholders the ability to see how an entire project is coming together. In scenarios where a design utilizes prefabricated materials and components like in mass timber, there is even greater emphasis on installation verification before proceeding to the next stage.
Not only must subcontractors have complete project line-of-sight, but engineers must also know when a building design deviates from architectural renderings and where on-site/in-field improvisation may be required. Lacking that line-of-sight could have negative downstream consequences for other trades resulting in lost time, money and project delays.
Last, as-built documentation provided by 3D laser scanning helps fulfill contractual obligations between contractors and other project stakeholders. By leveraging the capability of accurate and reliable 3D data, stakeholders can be certain that work was performed correctly, on-time and on-budget.
Combined with sophisticated software that allows users to create detailed 3D visualizations of real-world objects and environments, like stairs, roofs, walls and flooring, and export that data in various formats, project stakeholders can be confident that their mass timber project is on track to achieve mass success.
Going Against the Grain?
While it remains true that mass timber construction has its challenges, namely a lack of awareness of the building material, concerns over scalability at industrial levels, regulatory barriers, insurance costs, and uncertainty over flammability, its benefits outweigh the materials’ perceived drawbacks.
And one of best ways to ensure mass timber’s moment turns into a movement is by augmenting the popular bio-mass composite with the most accurate and precise, data-generating technology that the 3D measurement industry can provide.
3D laser scanning is that solution. And as mass timber’s adoption rates continue to rise, the percentage share of the construction industry’s CO2 emissions will gradually decrease.
Such efforts are unlikely to prevent future winter heat waves in the near term. But along with multiple cross-industry sustainability initiatives, our "totally insane" climate will begin to stabilize, protecting the very forests of which mass timber’s future growth depends.
Build & Construct
Design & Plan
Maintain & Operate
As-Built Capture & Modeling
Construction Quality Control
Measurement Service Providers
Mobile Mapping Systems
As-Built
BuildIT Construction
Freestyle
WebShare
Webinaire
Numérisation 3D de pointe, essentielle pour des mesures rapides
Découvrez comment l'excellent débit de transfert des données de Leap ST et ses cinq modes permettent aux fabricants de numériser les pièces plus rapidement et avec une exactitude élevée.
solution de sécurité publique : Améliorer la sécurité grâce à la capture de la réalité
Transformez le travail de votre équipe en matière de sécurité publique grâce à la capture de la réalité en 3D. effet de levier 3D réalité capture et avancé logiciel forensic analysis, Plan de préparation à l'incident, and smarter, safer sécurité publique process.
