Weißes Papier
Portable vs. fixed coordinate measuring machines (CMMs)
3DM Portable vs Fixed-IC Thumbnail 500x272
When is it better to use a portable coordinate measuring machine (CMM) over a fixed CMM, and vice versa? Is one solution better than the other?
Your decision on whether to invest in a fixed versus portable CMM will be based on a composite of answers to questions such as:
  • Size of parts to be measured
  • Actual level of accuracy required
  • Throughput requirements
It’s not likely that any one aspect will provide a make-or-break answer, but this whitepaper will help you examine the differences and help your team determine which solution is better in addressing your unique inspection needs.
Weißes Papier
Fertigung
Fertigung und Montage
Luftfahrt
Automobilindustrie
Aus- und Weiterbildung
Energie und Rohstoffe
Schwermaschinen
Gummi und Kunststoffe
Tragbare Messarme
Lasertracker
Bewusstseinsbildung
Filter
Filter
