Artikel
10 Gründe für den Einsatz von Laserscanning in der Forensik
forensic-ls
Laser scanning is rapidly gaining acceptance and becoming more and more commonplace in the law enforcement and accident reconstruction communities. Over the past few years, hardware and software have improved significantly creating a simpler, overall system to capture immense detail in a short period of time.
These are 10, of the many, reasons to consider laser scanners for a forensic application:
1) Easy to use: Many manufacturers are moving toward a simpler interface making operation of the scanner more like a digital camera than a complicated survey instrument.
2) Portability: Laser scanners are smaller in size today than ever before making them easier to deploy to a crime/accident scene and useable by just about anyone.
3) Safety: Data can be collected from a distance, with some scanners collected measurements over 300 meters away. This allows the operator to scan a scene out of harms way. In addition, laser scanners can collect up to 1,000,000 points per second with average scan times of several minutes. Less time on a scene means less time for potential danger to the individuals at the scene. Class I lasers are also being used in laser scanners creating a truly eye-safe environment during the scan.
4) Speed and Efficiency: Complete color scans can be captured in as little as several minutes creating a virtual scene with high accuracy and detail that can be revisited over and over without physically traveling to the site. In contrast to traditional methods of surveying/documenting a scene, laser scanning can be much faster and allow multiple investigators to have eyes on the virtual scene.
5) Produce a variety of deliverables: Once the scene has been laser scanned, various types of final products can be extracted or produced from the data. For example, anything from a traditional 2D drawing to a detailed 3D animation can be created from the scan data.
6) Gruppendruck: Da immer mehr Agenturen Laserscanner für ihre Szenendokumentation einsetzen, wird das Ergebnis immer mehr akzeptiert. Ebenso wächst die Erwartung, dass zukünftige Szenen in 3D dokumentiert werden.
7) Kosteneffektiv: Laserscanner sind preislich immer mehr mit Totalstationen vergleichbar, die traditionell zur Dokumentation von Verkehrsunfällen eingesetzt werden.
8) Spezialisierte Messwerkzeuge: Die Software für die forensische Analyse von 3D-Daten enthält jetzt auch spezielle Werkzeuge für die Messung von Blutspritzern und der Flugbahn von Kugeln, der Höhe von Zeugen/Verdächtigen usw.
9) Einfach zu teilen: Es stehen weitere Software-Tools zur Verfügung, um die Scandaten zu betrachten und zu dokumentieren, ohne dass eine Software installiert oder zusätzliche Lizenzen erworben werden müssen.
10) Archivieren Sie die Szene: Sobald die Szene mit dem Laser gescannt wurde, wurde sie im Wesentlichen in der Zeit eingefroren und für zukünftige virtuelle Besuche von jedem, der die Szene untersuchen möchte, aufbewahrt. Dadurch können auch Messungen vorgenommen werden, die zum Zeitpunkt der Aufnahme nicht unbedingt als wichtig erachtet wurden.
Artikel
Tatortuntersuchung
Unfallrekonstruktion
Ermittlung bei Verdacht auf Brandstiftung
Störungsermittlung
Forensisches Engineering
Strafverfolgung
3D-Scanner
Rekonstruktion und Analyse
Inbetrachtziehung
Filter
Filter
Série Quantum X FaroArm®
GeoSLAM Geospatial Technology
FARO® Super 6DoF TrackArm
